Here's the PLAN!!
Alright, after researching through the forum, and chatting with a few of you, I've come up with a plan to modify my 2008 4 Door, automatic transmission JK.
4.0 long arm lift, swaybar disconnects, adjustable track bars and steering stabilizer. 35" tires on 17" inch wheels, heavy duty spare tire carrier. ARB front winch bumber with Warn Powerplant winch. 4.88 gearing. Rock Rails. Aftermarket front driveshaft. Evap, SS, and Muffler relocate kits. Now, where do you see problems, what should I look out for, and have I missed anything? Looking for any and all advice. Thanks, Mac |
Originally Posted by N2rock
(Post 730194)
that much lift on an automatic- when you flex off road the front driveshaft boot will hit the transmission pan and/or skid, and will tear the boot off. You'll ultimately have to replace the front driveshaft for one of the smaller diameter aftermarket ones.
So, would you recommend a lower lift? Maybe a 2.5 instead? Would I then need to go to say, 33" tires? Or will 35's still fit? Thanks, Mac |
(Post 730194)
Mac |
Originally Posted by Breaktrack
(Post 730233)
Also, since you're here in the area, any good shops around you'd recommend? I have been talking to the guys at 4WheelParts, both the one on 1960 north, and the one on Westheimer. Any pros or cons there?
Find a real shop.
(Post 730219)
Ah, right off the bat...lol.
So, would you recommend a lower lift? Maybe a 2.5 instead? Would I then need to go to say, 33" tires? Or will 35's still fit? |
(Post 730219)
Originally Posted by tgrt
(Post 730274)
cons = 4 Wheel Parts
Find a real shop. I'd recommend getting the drive shafts. You very well may regret the smaller lift, but you won't great the drive shafts. Thanks, Mac |
Originally Posted by jeepsanddrums
(Post 730286)
I wouldn't go with a smaller lift. Especially on a 4 door. I would plan on replacing the front driveshaft.
Do you think the combination of the lower lift and then an additional body lift would be enough to do the same thing, but without the drive shaft issue? Thanks, Mac |
Originally Posted by jeepginn
(Post 730287)
My brother has a auto with a 2.5inch lift, 1 inch body, JKS trackbars and 35's. It wheels like a beast. He also has 4.88 gears and is happy with them. Good luck on your project...:thumbsup:
So the 4.88's provide enough power without any problems? I'd heard the 5.13's were better if running 35 inch tires, but if not needed, then 4.88's would be fine with me. Interesting. Thanks, Mac |
Originally Posted by toad
(Post 730357)
Contrary to what some have said..you having a 4-door doesn't mean you have to replace your driveshafts if you get a lift. I've heard that you have to do that only in a 2-door since there is a sharper angle on the driveshafts when you lift it. Since you have a longer wheel base, I doubt you will have to replace the driveshafts.
Lot's to think about, and only about a month before I plan to get started...lol. Thanks, Mac |
(Post 730358)
Is that due to the longer wheelbase? It would appear it would take more to clear obstacles with the longer vehicle, much like my old cherokee's I had in the past.
Do you think the combination of the lower lift and then an additional body lift would be enough to do the same thing, but without the drive shaft issue? Thanks, Mac Also.......after adding bumpers, winch, camping gear, airing down, etc...., your jeep will be sitting slightly lower. |
| All times are GMT -8. The time now is 01:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
