HighRock Rocker Trim
Old Nov 6, 2007 | 12:26 PM
redWRANGLER's Avatar
Default HighRock Rocker Trim
http://www.quadratec.com/products/12536_500_07.htm
Has anyone purchased and installed these yet? I'd like to know how well built and effective they are. I also like the door handle guards that come with it.
Old Nov 6, 2007 | 01:00 PM
Smoke6's Avatar
I've never seen those before, but it said they are made of PLASTIC. For $50 more you could get a set of Rubi rockers. They give you the finished look, but are fairly durable. JMO
Old Nov 6, 2007 | 01:33 PM
I have the Mopar steps, they don't work with the Rubi rockers because they use the same mounting points. I'm looking for something to clean up the body seem.
Old Nov 6, 2007 | 01:34 PM
Smoke6's Avatar
I see where you're coming from now. It very hard to tell from the pic.
Old Nov 6, 2007 | 01:36 PM
Old Nov 6, 2007 | 01:51 PM
Thanks Toad, I saw that thread and it's a good mod. What I didn't like is that he just used adhesive. The HighRocks use adhesive and bolt on.
Old Nov 6, 2007 | 02:03 PM
OffTopic's Avatar
I'm a "she"!
It would be very easy to drill a few holes in the aluminum that line up with the holes that are on the seam. There are already a few flange bolts in there, just a buy a few more (from the HighRock installation instructions I believe that M6 x 20 are the correct ones) and you can easily bolt the aluminum strip on. I'll probably do that myself in the future.
Old Nov 6, 2007 | 02:06 PM
My bad and good idea. I like how high the HighRocks come up as well.
Old Feb 5, 2011 | 06:11 AM
Karla's Avatar
Hello everyone! I know this is an old thread, but I wanted to resurrect it since I just bought the rocker trim from Morris on "clearance". I didn't pay enough attention to the installation details and missed that it uses both bolts and adhesive strips to hold it in place.
My question for you guys is: will the adhesive strips damage the paint on my JK? Also, how sturdy is the adhesive Bestop uses? Before installing this item, I want to make sure they won't come loose in the future; taking my beautiful paint with it.
Thoughts?
Thanks for your help!
Karla
