How can I be able to have fog lights on, on both high and low beam
Sent them an E-mail for the Jk model Brite Box and this was thier reply below..Par for the course.
Unfortunately we do not have this product for your vehicle, we are sorry for any inconvenience.
Thoroughbred Diesel
866-737-4966
Mon.-Fri. 8:00-7:30 EST
Saturday 9:00-2:00 EST
Thoroughbred Diesel Performance - Dodge Cummins, Ford Powerstroke, Duramax Diesel Parts
Thoroughbred Diesel
866-737-4966
Thoroughbred Diesel
866-737-4966
Thoroughbred Diesel
866-737-4966
One of the problems with doing this is the bulb and connector type on later JKs. The H13 connector can bairly handle the current of one light... The ground pin is common while the two elements have their own pins. 3 total. When both high and low beams are on, the current on the ground pin is doubled. Prolonged use (more than a flash) could cause the pin to overheat and melt. If this is something you really want to do you should look into an H4 conversion. It uses far larger pins. (Don't just get the connector adapter. It will still have the weak link. You will need to completely replace the connector.)
I would like mine to stay on with high beams as well but im just gonna wait till some one releases or hacks a program that i can download and mod settings on my ECU with.
