How do you tell if the frame is bent?
I have been trying to figure out a death wobble issue and noticed that one side sits hire than the other. Long story short I broke my axle housing on the right side so I have had to replace most everything. After measuring from the ground to a spot on the bumper it shows that the side I broke sit about an inch lower than the other. I checked my springs (which are new) to make sure they were seated correctly but no luck. Is the any other way to check if the frame is bent? If it is could that be the cause of the death wobble?
The right side sets down lower than the left on almost all jeep JKs.
Originally Posted by Robar
(Post 1956440)
Originally Posted by 07RubiconTX
(Post 1956465)
By an entire inch? I also noticed that my sway bar sits about a 1/2 inch different up and down and the passenger side is about a 1/2 inch more towards the center. This is a rubicon by the way.
The only way to check a frame is to go to a body shop that has a frame machine. You will never be able to tell with a measuring tape. Unless you were in a major accident or a roll over, you should not worry about a bent frame. |
(Post 1956440)
Thanks for getting this information up! It's helped me out! |
I was in a off road mishap where i landed on that side. I figured it could have bent it as well. I never noticed it was leaning before all this. Also it is modded with bumpers winch 3'" teraflex lift, ect.
Originally Posted by JKStell
(Post 1956474)
I'm glad I found this! I noticed a few months ago that my right side (front and rear) sits about 1/4" LOWER then the left/driver's side! I was a little concerned, but for what my Jeep has been through (although nothing like a rollover or a good "WHACK!") I didn't know if it was supposed to be like that or not.
What kind of off-road mishap happened to you? I know you said you LANDED on that side...what happened? Sounds bad...or just NOT good, at the very least! :sad2:
1 Attachment(s)
JK gangsta lean, mine wasn't as bad until I got in a wreck, got hit on the pass side rear qtr. Was only about 1/4in lean before, now it's 3/4in difference.:crazyeyes: I also had to change out the rear housing. Pretty sure the frame was tweaked.
Attachment 105484 |
if you have adjustable front swaybar links. make one longer than the other. Usually you will have to adjust the right side longer than the left and the Jeep will become more level.
