How does one replace control arm bushings?
Old Nov 16, 2009 | 08:06 AM
JeepyJeep's Avatar
Default How does one replace control arm bushings?
Got these replacement bushings for control arms...how do I remove old and replace with new. I have a feeling it's not as easy as it looks.
Pics of replacement bushings...
Old Nov 16, 2009 | 08:20 AM
SCF's Avatar
SCF
Typically a press is used to push out the old bushing, and to install the new bushing.
Any press will work really, just need a press and a impact socket just a little bit smaller than the bushing.
Old Nov 16, 2009 | 08:23 AM
JeepyJeep's Avatar
Any pics of the press you mention above?
Old Nov 16, 2009 | 08:25 AM
wayoflife's Avatar
JK-Forum Founder
if you have access to one, a standard H-frame shop press is what you want to use but... i have heard people use a ball joint puller too.
Old Nov 16, 2009 | 08:34 AM
Dizzyliz's Avatar
Talking even a chick can do it
I used a plastic mallet and a flat head screwdriver.
Then used window cleaner to lubricate so that the new ones would slip right back in
Old Nov 16, 2009 | 08:46 AM
wayoflife's Avatar
JK-Forum Founder
LOL!! i love your workbench dizzy
just so there is no confusion, the bushings the OP has are bonded rubber and a bit different. however, i suppose pounding on them with a hammer like you did might get them out too
Old Nov 16, 2009 | 08:52 AM
Dizzyliz's Avatar
Cool
I wasn't sure because mine look different from his but thought I would share anyway just in case
& Yes, the "workbench" is quite multifunctional
Old Nov 16, 2009 | 08:55 AM
RedneckJeep's Avatar
Liz dear......that's just so hot on so many levels I can't stand it.
Old Nov 16, 2009 | 09:01 AM
Dizzyliz's Avatar
Cool
Hey, I can even change my own oil.
Old Nov 16, 2009 | 09:03 AM
racer83l's Avatar
I dont own a press.. but a long bolt, nut, sockets and a few washers also get the job done... put socket that is LARGER than the bushing on one end with large opening towards bushing, put washer and bolt through socket and bushing.. place washer that is about as large as the bushing but smaller than hole in arm on other end.. thread on nut. TIGHTEN, it will press the bushing through the hole in the arm and into the socket...
to reinstall new bushing, basically remove the socket, use washer LARGER than the hole in the control arm (where socket was), and tighten the nut again. it should effectively press the bushing in. I like doing it like this as compared to a hammer or whatever besause it shouldnt damage anything, and is done slow, controlled, and straight.
back in the day when I had a broken leg and was rebuilding a dirtbike (old 1989 KX 250) I used this trick all the time as I couldnt easily get to a machine shop. its just the way I do things now
