how to measure pinion angle?
You don't need to remove it to check the boots, just crawl under and look. (I had actually assumed that this was already done, and the boot was good). Anyway, very easy to see if the middle slip-joint boot is torn and flapping around.
If that boot is good, the other problem area to look for is the joint at the tcase. If this one has split, you should see a very noticeable ring of grease on the undercarriage just above the joint.
And if the big boot in the middle is the problem, just rip it off. Then you can either run it without the boot, (and maybe just pull the shaft off once or twice a year, depending on use, to clean and re-grease,) or buy a new boot (which will likely tear just like the stock one), or go to a thinner aftermarket shaft.
Those were just 2 recommendations on things to check earlier in the thread. Not meant to be done together. I was just asking if he had done those yet since he was asking for more possibilities and I hadn't seen the results of these 2 tests posted. I suggested he check the boot and another member suggested disconnecting the ds to rule that out.
Ok finally got under the jeep. No tear or grease but the angle of shaft into tcase is steep. Took the shaft off and went for a ride and the noise is gone. I have adjustable lower arms but thinking I need upper arms now. Will that fix the problem or is my driveshaft the problem?
Shorten the lowers to raise the pinion / lower caster
Lengthen the lowers to lower the pinion / raise caster
Adding uppers also will allow you to move the entire axle forward/backward in the wheel well, and gives a better range of adjustability and fine tuning for caster/pinion.
As you go higher, caster/pinion angles are a balancing act. The only way around it is to cut and turn, or go to a caster corrected aftermarket housing.
Former Vendor
Adding the upper arms will help you fine tune your pinion angle, however it is doubtful that it will correct your noise. Feel the DS joints and see if you have any binding. If you do that is likely the source of the noise. I would say that a replacement DS will correct your noise based on what you have said.
