How much actual lift from BDS 3” ?
Here's some searching I tried for you. These are all dealership online websites run by their Mopar parts department. You'll notice a common template webpage theme about them.
Oregon $880
https://www.makeitmoparparts.com/acc..._77070089.html
Here's the lowest I've found so far....Kansas dealership. $775
https://www.moparpartsforyourride.co...IFJlc3VsdHM%3D
unsure of location: $775
https://www.factorypartsking.com/oem...IFJlc3VsdHM%3D
It also may be worth contacting this seller on Ebay. They have the 2 door version listed for $800, free shipping, no tax. They're likely a dealership, and are likely drop shipping from a Mopar distribution center. I'ld contact them and ask if they can get P/N: 77070089 for you which is the 4 door version of the same kit. Just different rear shocks and springs.
https://www.ebay.com/itm/2007-2011-J...gAAOSwjuBZm0CL
Doing a more Apples to Apples comparison, this is the MetalCloak Rocksport kit with the same shiny Fox shocks. $1700. It's definitely a nice lift. Adds a front TB, brake line hoses, upper control arms for caster correction, and brake line extension brackets for an additional $900 over the Mopar kit. Definitely a good quality kit.
https://metalcloak.com/jeep-jk-wrang...x-edition.html
Unsure I'm able to see the strength increase in the MC rear TB relocation bracket. Both look like they're designed to also be used on their 3.5 and 4in lifts, so likely strong enough for heavier 37in tires and be able to handle 35s without a problem.
The Metalcloak runs down and braces on the rear lower control arm mount as well. Shiny parts aren't how kits should be bought. I have the Metalcloak, pieced together through the years and members, which has allowed me to spend the extra cash on steering upgrades.
I'm also unsure about the benefit of running the bracket brace to the rear lower control arm mount. It looks like that may add an unwanted point of potential damage to the bracket and/or control arm mounting bracket by putting the bracket support on the bottom side of the axle where there's more potential concern of clearance related damage. The Mopar bracket seems to put the bracket support around the axle tube with more support on the top side of the axle tube instead, thus more support overall and more of the bracket out of harms way. To the eye test the Mopar bracket looks a bit stronger to me as well but I think it's all a mute point since they both should work fine for 35s and raising that rear track bar up like it should be.
I also don't believe the throw away Fox shock are any better then the Rocksport that are specked for that lift. All you are doing is paying for the Fox name and shiny shock body. Apples to apples is referring to components in the kit not the brand of any specific part.
I know you need to justify your purchase to everyone but being it is the only lift you have had, that kit is really is not a good recommendation vs others out there.
Onto more productive things. I know you know a ton more than me on these things and have much more experience. Let's focus on comparing those rear track bar bracket designs. Let's take price out of the equation. If I was in the market strictly shopping for a rear track bar bracket and I had the choice between the MC or the Mopar which would you choose and why? I love me some MetalCloak but when I look at both of those rear track bar bracket designs with a critical eye, I really think the Mopar bracket looks like the better overall design. Yes, I'm asking you to try and set your name brand biases aside and compare the Kirkland (Mopar) to the Nike (MetalCloak) and critique each of their designs while attempting to ignore the brand names just as you requested with the shocks.
And afterall, you did mention the MC came with a heavier track bar bracket which I'm just not seeing.
When I look at them, the Mopar looks heavier to me and I'm thinking you may have just been not as familiar with the Mopar when you made that statement.
MC, Teraflex, and Clayton offroad all have a very similar rear track bar mount, I know the MC one isent "adjustable as they make an adjustable track bar and i know the teraflex is adjustable. Im not to certain about the mopar version as no one local runs their lift and have never seen it in person.
The Mopar bracket does the same where the bottom hole is for their 2in lift TB mounting and the top is for their 4in lift TB mounting.
Metalcloak bracket is not adjustable, it's one height fits all. The top hole is tapered and the bottom isn't.
