How strong D-rings should I get?
I purchased the arb 17800lb snatch strap. The store a bought it form also told me to get some 4 3/4 ton D-ring shackles. I want to check with you guys to make sure that those are strong enough. If something breaks i do not want it to be the D-ring because it will become a projectile. I also wheel with a long bed dodge ram from time to time so I might need to pull him out or have him pull me out. Thanks for any help.
the pin is probably going to be your limiting factor
tabs on the bumper will only except up to 3/4 inch in most that I know of
2000 lbs = 1 ton
crosby was mentioned and they make the nice strap savers if these are not specifically for you bumbers otherwise there are quite a few 3/4 rated well above your pulling capacity
2000 lbs = 1 ton
D-rings can hold way more than they are rated for I've used those size d-rings to pull around a 60,000 pound drill rig numerous times and the only thing that I've had break are numerous chains and straps
