Hub centric or lug centric which one is it?
#21
I will agree to disagree.
After some thought, this debate really serves no purpose because if you use spacers then your wheel instantly becomes lug centric because it is mating to a flat surface and if you purchase aftermarket wheels they will also be lug centric because most use a generic opening to fit numerous vehicles with the same bolt pattern. Very few are designed specifically for one vehicles. So really what difference does it make.
#22
Actually alot. Hubcentric wheel spacers not only have a bore of specific size but also have a 'hub' the very same size. So while the spacer is hubcentric to the hub, the wheel is hubcentric to the spacer. Again, the lugs do not support the weight. And as for aftermarket wheels, most do in fact have a larger hub bore that is 'sized' by using hubcentric adapter rings. Some adapter rings are plastic and I'm not a big fan of using plastic rings (although they do a fine job of centering the wheel for lug tightening) but usually you can find billet rings that will do that trick.
I still haven't popped off a tire to check to see if the steelies are hubcentric but I'd bet they are.
#23
Does anyone know the size of the stock hubs? I would like to mount my Cragar soft 8s, but I want to buy hub rings to center them (i don't know the hub size of the wheel either). Some sizes are listed here: http://www.1010tires.com/hubrings.asp
#27
Well the Crager Soft 8's have a 3.3" center bore, nota4re says the hub is 2.8"
I found an online conversion and here is what I came up with:
3.3071 84.0000mm Crager Center Bore
2.7953 71.0000mm \
2.8346 72.0000mm / Closest match for Center bore.
I don't see a match on http://www.1010tires.com/hubrings.asp
I have no idea wether or not you can use them on steelies or not even if they did fit.
2.7953 71.0000mm \
#28
There are lots of people running steel wheels on Jeeps. I have never heard of one falling off due to it not being hubcentric. Before aluminum wheels started showing up on new cars they were all steel. I never heard of problem with those either.
