Hypertech or AEV ProCal Module??
Old Feb 17, 2009 | 12:09 PM
  #21
sacdaddy03's Avatar
I went with the ARV Procal....REAL easy to use, REAL fast!! I went with this bc most of the ppl with hypertech isn't reporting much different feel with hp/tq....So that wasnt enough to justify the extra money!! I have an auto with 285 and now it rides and 70-75 NO problem on the interstate, you can diff tell the difference with the shift points "corrected"(change)!!
Old Feb 17, 2009 | 12:45 PM
  #22
JPop's Avatar
Put some other bolt on performance enhancers on your JK and with the Hypertech Max Energy you're really left with an expensive AEV ProCal. Had I had it to do over again, I definitely would have waited for the ProCal and ran with the Jet Stage II programmer. Much more intake and exhaust friendly.
It's also funny that Hypertech doesn't feel any need to take a look at their program for the JK for after market add ons, but evaluated 10 popular cold air intakes for mustangs. I guess it's nice not to have much competition in the JK market and they seem to be milking it for all it's worth.
Old Feb 17, 2009 | 04:12 PM
  #23
tambil68's Avatar
I'm not sure of their intentions, but the hypertech does update the firmware. I think the laws of supply and demand are what dictate the resources put into this, there are certainly more mustangs on the road then JK model jeeps. Of course we are now on year three for the model, and the new platform, (3.8l ) so we should see more improvements everyday.
Regarding the difference between the two.
The Hypertech reprograms your engines parameter tables for better performance. You might not "feel" it so much, but it is there.
The AEV Procal unit adjusts "selectable" features. Thats all. It doesn't reprogram or change anything about the engine.
Now those two points in relation to the OP's question leave these results.
It's up to what you want to accomplish as with any modification. Hypertech is a better tuned, better running engine and corrected tires/gears.
AEV Procal is user features customized, and corrected tires/gears.
I really enjoyed my Hypertech, but have to use the AEV because once I put the supercharger on, I can no longer run the performance settings of the Hypertech. But I need to have the tires/gears set correctly.
Both units enable the auto to shift correctly IF you are NOT running stock.
Hope this helps...along with the other insightful posts in this thread.
Old Feb 17, 2009 | 04:41 PM
  #24
nangulator's Avatar
Originally Posted by nlgrav182
Sounds like Hypertech is the better deal considering your features. Obviously cost is a concern ($379 vs $145 I think?) but the extra HP and the ability to change tire size and gear ratio is a win in my book.
The hypertech may change shift points but it does not add any horsepower
Old Feb 17, 2009 | 04:45 PM
  #25
tambil68's Avatar
Just curious as to your experience and why you think that? (honestly)
My personal experience has been excellent. Def increase in power, and much smoother performance to me.
Old Feb 17, 2009 | 04:55 PM
  #26
JPop's Avatar
Hypertech gets there lunch eaten on just about every last platform they run on. If they compete against Diablo or Superchips on a given platform, they lose. The JK with a captured audience, modest if any performance gains and seemingly an unwillingness to set targets for the more than half of their users with exhaust and intake upgrades. Simply stated by Hypertech's management was "This isn't something we need to tackle".
Old Feb 17, 2009 | 05:11 PM
  #27
AZJeeper's Avatar
Community Favorite
Really? You talking about the Max Energy or the speedometer calibrator?
Between the AEV and the Hypertech Max Energy, Both:
  • Read and clear DTCs
  • Change Gear Ratios
  • Change Tire Size
AEV has what Hypertech doesn't:
  • TPMS adjust (Hypertech says "Maybe" in the near future)
  • Daytime running lamps (not high on my priority)
  • "one touch" turn signals (mine came from the factory that way)
  • Temporary idle speed increase (cool feature!)
  • Steering centering option (see Aeroforce gauge below)
Hypertech has what AEV doesn't:
  • Change power settings - premium and regular fuel settings
  • Change default fan turn-on temp
Hijack-Add a Aeroforce gauge, and you get:
  • 50+ engine parameters to monitor (including steering centering)
  • High and low speed fan control
  • Custom gauge inputs
  • ESP Disable (worth every penny)
My Max Energy certainly increased HP. Better on premium but regular is noticeable. Have no complaints at all. Add in the Aeroforce gauge and you have a near-perfect package (IMO). Now if Hypertech would just address that damn TMPS...
Old Feb 17, 2009 | 05:48 PM
  #28
tambil68's Avatar
AZ
Thank you. That is a great comparison statement there. I totally agree!
Edit: Oh hell yeah... the aeroforce gauge is awesome. Just installed mine. Which platform did you use? It gives three options as Platform 1, Platform 2, Platform 3
Old Feb 17, 2009 | 05:54 PM
  #29
JackMac4's Avatar
Just a small footnote to add, there is a little confusion I think in this thread - some people when talking about HyperTech are referring to the AccuPro whereas others are referring to the Max Energy.
Old Feb 18, 2009 | 06:20 AM
  #30
ThinkMud's Avatar
Well I ordered the AEV from quadratec and it's back ordered
But as soon as I get it I'll post results. Mainly I just want my speedo corrected and the shift points better. Also want to lower my air pressure warning. And the higher idle for winching would be awesome. I don't care about HP or anything, the JK is efficient enough for me and the power is fine for crawling.
