Hypertech Programmer
[QUOTE=shrockworks;331032]
Darnell, what happens if you run reg. unleaded with the premium fuel setting? QUOTE]
He's the expert, but I'm guessing you may get some pinging from the more aggressive ignition curve of the "premium" setting.
I just saw this posted elsewhere but I'm not sure if the vendor is a sponsor so I won't post it. If you do some checking around though you should be able to find it.
"Hypertech has released an online update which allows their 52001 Max Energy Power Programmers to work on the 07-08 JK's with claims of +8 hp / +16 ft-lb increases on regular fuel and +11 hp / +24 ft-lb increases on premium fuel. These also have the ability to recalibrate the speedometer for larger tires."
just wondering... but since these things can correct tire size and such... can they be used accross multiple JK's? in otherwords, lets say i get one, and someone i know got larger tires and wants me to recalibrate his. would it do it even though its programmed my jk? i ask because i've heard some of these programers will only work on one car at a time and the only way to adjust another is to set the first one back to normal. does this hypertech one do that as well?
I believe that they are single vehicle use. You cannot program a second vehicle until the first vehicle is set back to factory default. But I could be wrong.
