Sponsored by:
Sponsored by:
Icon JL 2.5" coil spring lift kit now available!!!!
Old 03-13-2018, 12:41 PM
LGE*CTS MotorSports's Avatar
Default Icon JL 2.5" coil spring lift kit now available!!!!
2018 + Jeep JL ICON VEHICLE DYNAMICS 2.5" lift kits are now available for order now!!!
ICON Vehicle Dynamics is excited to provide a sneak-peek into the development of a 2.5” suspension system for the new 2018 Jeep Wrangler JL. Aimed at drastically improving (not just maintaining) on and off-road ride quality this system includes dual rate coil springs, 2.0 Aluminum Series shocks, link arms, front and rear bump stops, sway bar end links, and all necessary hardware for a complete install. The JL is a much more “refined” vehicle compared to previous Wranglers, and with improved suspension geometry and more robust components this new Jeep sees significant performance gains with the introduction of ICON suspension products.
Through an accelerated testing process dubbed the “ICON1K” R&D program, ICON has logged over a thousand miles in the dirt pushing the JL to off-road extremes to identify limiting factors in OE components, develop products that remove these limits, and further extrapolate performance out of this vehicle. This 2.5” suspension system has been tweaked, tuned, and revised several times over the course of this ICON1K testing in an effort to provide unparalleled ride quality and vehicle dynamics for everything from rock crawling to high-speed desert running. By removing the aforementioned “limiting factors” this ICON suspension system completely redefines the potential of the 2018-UP Jeep JL with wheel travel gains over 30%!
This ICON Vehicle Dynamics 2.5” suspension system will allow for the use of a 35” tire, while ICON Alloys offers wheels in both a 4.5” and 4.75” backspace that provides ideal fitment for the varying axle widths found on Rubicon and non-Rubicon models. For those who are looking to install a 37” tire, ICON will be offering a bump stop spacer kit that allows for this as well. Additional ICON JL components are currently in development, so be sure to keep your eyes out for an official release on the COMPLETE 2.5" suspension system lineup in the coming weeks!
KEY FEATURES
  • 2.5" lift height
  • Fits 35" tires (37" with bump stop spacer kit)
  • 3" front, 2" rear increase in wheel travel
  • Improves on and off-road ride quality over stock
  • Dual rate coil springs with lifetime guarantee against sagging/breakage
  • 2.0 Aluminum Series shocks with vehicle specific valving
  • 100% bolt-on system makes for an easy install
  • “ICON 1K” tested under rigorous off-road conditions to validate tune, performance, strength, and durability
WHEEL & TIRE FITMENT INFO:
  • OEM Wheels & Tires: Yes
  • [NON-RUBICON] Aftermarket Wheels: 8.5″ Wide, 4.5″ Backspace
  • [NON-RUBICON] Aftermarket Tires : 35" x 12.50 (Larger tires will fit with recommended bump stop spacer kit and minor trimming)
  • [NON-RUBICON] Recommended Wheel: ICON Alloys 'Rebound' 17x8.5 / 4.5" BS / -6mm Offset
  • [RUBICON] Aftermarket Wheels: 8.5″ Wide, 4.75″ Backspace
  • [RUBICON] Aftermarket Tires: 35" X 12.50 (37" tires will fit with recommended bump stop spacer kit)
  • [RUBICON] Recommended Wheel: ICON Alloys 'Alpha' 17x8.5 / 4.75" BS / 0mm Offset
SEE THE ICON JEEP JL 2.5" SYSTEM PREVIEW VIDEO HERE!!!
CALL FOR PRICING!
INSTALL AVAILABLE!
(909) 599-2228
john@lge-cts.com
Ask for John
Quick Reply: Icon JL 2.5" coil spring lift kit now available!!!!
