Installing Electronic Sway-bar Disco on non-Rubi Models
#21
Could someone PM me a link to the guy with the YJ that put one together? I'd like to see how he did the electrical side of it. A good thing about this is that you can clock the motor when you fab up your own mount.
#22
#24
Ordered mine from my dealer....worst case I'll just hook it up manual like the guy in the YJ thread did. Anything has to be better than trying to get the disconnects lined up again, especially in the cold.
Anybody check to see if the wires are run already and just tucked up somewhere?
#25
If I remember correctly, the whole board behind the 5 switches connects to the bus. So I would assume that the wires that connect to the disconnect would also connect to the bus. I'm wondering if you would need to do a computer flash once you install everything to tell the computer that the disconnect is there so it knows what to do when you press the button.
#26
My goal is to use the Rubicon switches with mine. it will require a switch and it might even require a computer flash.
If anyone gets to it, let me know if the wiring is already there etc. it would be beautiful if i could just plug it in.
#27
I personally will be wiring the switch directly to the backside wiring. I want to be able to use the disconnect feature in 4HI was well as 4LO.
#29
#30
picture from http://www.jeepforum.com/forum/showthread.php?t=358591
