Insul-Liner -- Insulated headliner
Just installed an insulated headliner set from Insul-Liner.com. I ordered the gray color, which matches the lighter of the gray trims used for the dashboard. The attachment method uses thin aluminum plates with a welded threaded attachment, 3M adhesive tape, and plastic screws/washers. The vinyl marine upholstery is foam padded, and neatly sewn over closed cell foam and two layers of foil. Total thickness is over an inch, and sits flush with freedom panel underside. At the rear, two side-by-side panels fit from the soundbar to the rear of the hardtop (2-door). The fit is perfect, and the quality is extremely good.
Winter installation: The 3M adhesive tape should have over 75 deg F for installation. It was 45 F today, so I put two blankets on the hardtop roof, turned the heater on high, and set the fan to recirculation on high speed. Suffice to say, after an hour it was a lot hotter than it needed to be.
Ready for the desert heat!
Looks really nice! Being that I left my hotheads outdoors (reason they look ruff), I will probably order another set. Worked great here in TX. I checked out yours and they are out of my price range :eek:
Sent from my Galaxy Note 2
