07-11 Auto to Manual Swap
I have a heavily modified Auto JKUR long armed on tons and 42's so trading is not an option. I am looking to swap the Auto for a Manual. 1 - because the 4 speed auto is junk and keeps over heating even with a dual cooler. 2- I also plan to swap in a TDI which requires the Manual tranny.
I have sourced the following parts for the swap.
NSG370 Remanufactured
Clutch Kit with flywheel and TO bearings ( complete kit)
Clutch Fork
Master and slave Cylinders and hose
Console and boot/ retainer
Shifter
Clutch brake pedal assy
2009 ECU for a manual.
Total cost so far is $3400
What I was hoping to find out is what wiring mods I will need to make to get it to work properly from someone who has taken on this task.
Thanks for your help.
Clutch Fork
Shifter
You may need a different pulse counter for the flywheel (not sure) and will have to modify the wiring to put the clutch interlock in for starting unless you don't want that. But that might affect the cruise control as you can push the clutch pedal to cancel cruise. Look at Rock Auto to see if the flywheel pulse sensor is the same from auto to manual. There will be some bypass wiring for the P/N interlock which is what you may need for the clutch interlock. Other than that I can't think of anything except perhaps the PRNDL display cancel. In my manual to auto/Chev conversion that display simply showed up when I switched it all on with the Motech conversion kit.
And you will need to enter the ECU program and tell it you have the manual and do some Network connection changes.
When you swap ECU that will work but there may be options in the new that were turned off or on depending on configuration. You can simply do that in yours without changing it but you need access through (what I use any way) HP Tuners or something similar. In HPT you just go the transmission menu and say "manual" and go to the network config menu and remove the auto tranny stuff. See attachment if it helps you.
So I've Come Across the following, This is for 2007 - 2011 Wranglers with the 3.8L, I can not confirm the following for 2012 + with the 3.6L
Like jrager explained the following parts are needed.
- NSG370 Transmission w/ Clutch Fork & Shifter
- Clutch Slave Cylinder, Master Cylinder & Tying Hydraulic Line
- Clutch & Pressure Plate w/ Throwout Bearing & Pilot Bearing
- New Flywheel w/ Bolts
- OEM Clutch Peddle Assembly w/ Master Cylinder Clip
- OEM Shift Boots (Inner & Outer) / Shifter Mounting Plate & Shifter Extender/Handle ( B&M Also Makes a Shifter Handle for an additional price)
- Dash Wiring harness for (2007 to 2010 / 2011 / ) for Clutch Peddle Interlock Switch OR as I'm researching the plug to the Switch and Pin location for separate wiring. Jeep will not start without this wiring or bypassed
- Engine Wiring Harness for ( 2007 to 2011 / ) for Backup Light Switch on Transmission
- Powertrain Control Module for ( 2007 - 2010 / 2011 ) - Manual PCM is Different from Automatic and a new PCM is needed, Used PCM can be used & skimmed to match VIN.
Extra - New Rear Main Seal - If Leaking this is a good time to replace it.
Programming
TIPM needs to be reprogrammed for Backup Light Switch Wiring and to remove the PRNDL from the dash.
Manual PCM skim or programming - RPM Extreme https://www.rpmextreme.com/ out of AL can reprogram PCM / TIPMs for this application. Otherwise, a Dealership might be needed.
I've reached out to all tuner companies including diablo sport / Superchips / holly and they informed me that this is far past their capabilities. HP tuners in unknown
Both the PCM & TIPM will need to be programmed to match VINs in order to work properly
Programming
