jeep shaking
Old Oct 20, 2009 | 01:07 PM
SoccerMan1080's Avatar
Default jeep shaking
Just put a ome hd lift in my jeep and it shakes only at 55 mph... Any thoughts on what the problem is and how to fix it?
-Adam
Old Oct 20, 2009 | 01:54 PM
mkjeep's Avatar
Check you suspention components torque, tire balance and toe in.
Old Oct 20, 2009 | 01:55 PM
mkjeep's Avatar
In addition, most speed related vibes and shimmys are usually a balance issue.
Old Oct 20, 2009 | 02:09 PM
RN M OVR's Avatar
Was going to say the same thing. I would check your tire balance first. If it still occurs after that then check your suspension components like track bar, drag link, and tie rod -- make sure they're tight and not loose (note: the tie rod is designed to have a little slack)
Old Oct 20, 2009 | 02:21 PM
Old Oct 20, 2009 | 04:00 PM
-MAW-'s Avatar
Check your tracbars first to be safe but at that speed if it goes away at 65 I would be looking at a balance issue
Old Oct 20, 2009 | 04:13 PM
CTNEDGE's Avatar
If your balance is correct you may find you have out of round tires. My Jeep shakes a bit at about 48 mph and I have gone through it extensively. Tire company concluded they are simply out of round.
Old Oct 20, 2009 | 05:14 PM
Ryanc's Avatar
x 2
Old Oct 21, 2009 | 10:08 PM
ok thanks for the help... i will check out the ideas and see if that will determine the cause.
-Adam
Old Oct 22, 2009 | 09:19 AM
spinlock's Avatar
If you just added the lift (no wheels or tires), it is likely to be you your steering system. If the alignment angles are within spec, check your torque specs as Mkjeep suggested. If they are OK, check for loose joints, the lift can put more stress on ball joints, bushings, pivots, etc., so it can magnify problems that are unnoticeable in a stock configuration.
The more details you can provide, the easier it will be for members of this forum to help you diagnose it.
