Jeep Wrangler jk 2012 superchips flashpaq gave me p0731 error code. Help!
Are you sure you have 3.21s and not 3.73s? If so, then I would try using the flashpaq to go back to stock. Then clear the codes. Then disconnect battery negative cable for 10 minutes. It's worth a shot at resetting the PCM.
And reverse should engage in limp mode. It just takes several seconds so be patient.
Do you have any other ideas how to fix it?
Thank you
Found this...
P0731 Jeep Description
This diagnosis monitors actual gear position by checking the torque converter slip ratio calculated by Transmission Control Module (TCM) as follows:
Torque converter slip ratio = A x C/B
A: Output shaft revolution signal from revolution sensor
B: Engine speed signal from Engine Control Module (ECM)
C: Gear ratio determined as gear position which TCM supposes
If the actual gear position is higher than the position (1st) supposed by TCM, the slip ratio will be more than normal. In case the ratio exceeds the specified value, TCM judges this diagnosis malfunction.
Assuming it's not mechanical (revolution sensor, ECM, tranny, wiring, etc.), which is too coincidental for me, I can't see how the flashpaq could change any of these variables unless the gear ratio was changed. Unfortunately it may need a reflash from the dealer at this point. Call Superchips and see what they say.
If you want to try to troubleshoot it yourself you can follow this process...here. It's for a WJ but should be similar I would think.
Good luck!
Good luck!
A few questions:
1. What year, make & model?
2. What does the tire measure from ground to top of tire?
3. Why do you believe you have 3.21 for gearing?
4. Did you follow all of the instructions that came with the Flaspaq?
The code you mentioned is definitely a transmission code.
P0731 - Gear Ratio Error In 1st
More questions:
1. Are there any other symptoms, i.e. hard shifts, no shift?
2. How many miles are on the Jeep?
3. When was the transmission last serviced?
4. Was the shop you went to a transmission shop? If so, how did they determine the transmission was ok?
Now for some advice. I would never, and I mean, never ever allow someone to mess with the settings of my Flashpaq. I just replaced the transmission in my 2010 JKUR and didn't allow a sole from the shop to touch my programmer.
Do NOT change your gear ratio setting unless you change your gear ratio and know what your vehicle is equipped with before you even access a setting on your tuner.
Changing the program your vehicle uses is very serious work, that if done wrong or randomly can have adverse effect on your vehicle and could possibly cause the vehicle to not start at all.
Unless you know for certain that you have 3.21 differential gears, you may need to go to a reputable transmission/driveline or auto shop or the dealership for some answers. They will have to pull the diff cover to verify the gearing.
The dealership will have the ability to scan your vehicle to get a better understanding than most shops but it will cost money. It could also save you money as they could possibly diagnose the problem quicker which leads to hopefully less money spent.
Just know, a good mechanic will fix an issue, a dealership will throw new parts at the problem.
The tire size setting only has affect on what your speedometer states the speed you are going. The instructions read to measure from the ground to the top of the tire and use that number (I believe rounded up to the nearest ¼ of an inch). Unless you bought perfectly made 35" tires, I don't think the setting will be 35"
As far as the gear ratio setting, I don't think anyone here, myself included can speak to that since we do not know for sure what you have.
Please reply with the answers to the questions above when possible and we will do our best to "guess" what your problem could be. More than likely though, you will want to seek professional help.
More questions:
A few questions:
More questions:
More questions:
I will take it to jeeo dealer today. I will keep you posted what was it.
Yes it has the current firmware :( anyhow i took my jeep at the dealership. And so far they are still checking out. According to them its not mecanic thing, they are making testing it seems that they have to re program once again the computer and ask for software to jeep factory. Anyhow that was what they told me yesterday, they will give me an update tomorrow. I will keep you posted guys
hi! so far they are still checking out. According to them its not mecanic thing, they are making testing it seems that they have to re program once again the computer and ask for software to jeep factory. Anyhow that was what they told me yesterday, they will give me an update tomorrow. I will keep you posted guys
