Jeeps with After Market Tie Rod in Stock Knuckle Location
Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
....I haven't noticed my tie rod touching the Solid cover. Likely because I still need to lengthen my adjustable LCA's a tad.....
This doesn't make any sense. YouR tie rod mounting points are fixed to the axle itself. If you rotate the pinion down, youR knuckles would rotate up and vice versa so the space between the diff cover and the tie rod would still remain the same.
