JK Alignment, need help from experts!
1 Attachment(s)
So I had 4 Wheel Parts put some new wheels/tires put on my 15 JKU Willys, put Pro Comp 7032 and BFG 33s on replacing the stock tires. I had them do an alignment but the alignment printout says at the bottom *one or more values are not w/in specs. Tire wear, handling and safety problems may result." I have suffered from a poor alignment which led to serious tire wear issues in the past. I have attached a copy of the printout, can I get some thoughts on this from alignment experts out there? Is this acceptable or will I see uneven tire wear down the road?
It's odd that your rear axle is out of spec. The caster will not change how the tires wear between Hampton and VA Beach but the negative camber up front is something to watch.
You've got a lift, correct? How many miles are on the jeep? Mileage and the terrible roads here could be the reason your camber is out (ball joints are bad). There's really no explanation for the rear being wrong unless they put the heads on incorrectly when they were setting up for the alignment. |
My rear toe looked like that with a offset axle. Adj track bar evened it right out.
(Post 4269856)
You've got a lift, correct? How many miles are on the jeep? Mileage and the terrible roads here could be the reason your camber is out (ball joints are bad). There's really no explanation for the rear being wrong unless they put the heads on incorrectly when they were setting up for the alignment. What concerns me is that the original alignment caused serious cupping, that is why I got the new tires. Seems if the camber didn't change after the 4 Wheel Parts alignment I am going to run into the same problems. |
Originally Posted by lachoy731
(Post 4269864)
I have a level kit it and 21k miles. Do you think that the alignment should be done again, should I contact 4 wheel parts on this? I didn't realize until a few days after I had the wheels/tires put on when I actually looked at the printout. They didn't say anything when they printed and handed it to me.
What concerns me is that the original alignment caused serious cupping, that is why I got the new tires. Seems if the camber didn't change after the 4 Wheel Parts alignment I am going to run into the same problems. 1. With a leveling kit, there isn't much to align on your Jeep. They can set the steering wheel straight if it's crooked (and you'd already be complaining about dash lights when turning hard if it wasn't). And they can set the toe. Unless you're not revealing all of your mods (I did check your "My JK" tab, which seems out-of-date since the only mods it lists are the wheels), there is nothing else that can be adjusted. Nothing. Steering wheel and toe is what you get when you pay for an alignment on a Jeep JK unless you've replaced non-adjustable OEM parts with adjustable aftermarket parts. Oh, and that fancy printout that often looks quite similar on a new from the factory just off the train JK. 2. Cupping is usually caused by a bad shock. Suggest checking them. Bear in mind that some tires are especially notorious for cupping easily. Blocky MTs are the worst. 3. The JK ball joints are notorious for wearing out quickly. You may want to check them out--plenty of YouTube videos tell how, or just have a competent shop do it. |
I hope u didn't pay $285 to have 4wp do that. Goodyear and lots of other shops coulda done exactly the same thing for less than $100. Ur caster is low. I assume u have a lift?
Originally Posted by cjnomo
(Post 4270143)
(Post 4270082)
Some random thoughts:
Thanks great info
Will a 4 wheel alignment check the wheel base and if off tell ya which wheels need adjustment.
