JK Battery terminals setup
I just wanted to show off my in a pinch setup, i had a cracked negative terminal that was causing xmas lights on the dash, and this was my in pinch solution and everything seems to be working great again. Opinions on the setup? Let me know what you think, i can take the criticism lol, thx
Not exactly what those terminals were designed for, but it looks to be working. Is this a temporary fix or are you looking to run it long term? It shouldn't hurt anything as long as you keep the bolts tight and free of corrosion.
I found a nifty solution on quadratec for battery wiring woes. It's basically a terminal bus. I'll snap a pic tomorrow if you want. Works good. Large terminal for the winch, smaller ones for the normal connections and sPOD.
