JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Jk Wrangler Leveling kit or JK 1.5" Performance Leveling (https://www.jk-forum.com/forums/modified-jk-tech-2/jk-wrangler-leveling-kit-jk-1-5-performance-leveling-184789/)
borrongo Jul 2, 2011 09:56 PM
Jk Wrangler Leveling kit or JK 1.5" Performance Leveling?
Since I'm installing 35s on my 2drs, 2011 Rubi, I'm still researching how to best accommodate the tires. I came across a 1.5 Jk Wrangler Leveling kit and a JK 1.5" Performance Leveling (Both by Teraflex). Both add 2" to front and a 1” the rear.
The 1.5 Jk Wrangler Leveling kit is coil spacers kit and it's cheaper. The JK 1.5" Performance Leveling comes with new springs.
Which one should I get?
cld1371 Jul 3, 2011 03:44 AM
Sent you a pm.....
Thanks.....
borrongo Jul 3, 2011 04:49 AM
Originally Posted by cld1371 (Post 2383149)
Sent you a pm.....
Thanks.....
Just replied!
eastcoasting32 Jul 3, 2011 07:28 AM
I'd like to know this one too
4fit? Jul 3, 2011 07:36 AM
If you intend to add heavy bumpers, then the coils would probably be the way to go. They won't sag as much as the spacers and stock springs. Keep in mind though that teraflex says this kit will clear up to a 34" tire. You will definitely be rubbing at flex with 35s, unless you go with flat fenders and/or extended bumpstops. May also need to trim your pinch seam.as well.
I personally went with the spacer version of this kit. Should be arriving next week. It was cheap and won't be anything that I'll take a huge loss on when I upgrade to a Teraflex 2.5" coil lift of Rock Krawler Stock Mod in the future.
borrongo Jul 3, 2011 08:31 AM
I will install an LOD Mid-Width Bumber and an winch. Also RR flat flares. With this set up, do you recomend the springs?
4fit? Jul 3, 2011 08:48 AM
Yes I would.
borrongo Jul 3, 2011 09:15 AM
Originally Posted by 4fit? (Post 2383434)
Yes I would.
Great...thanks!
sa29560 Jul 3, 2011 09:29 AM
Yes I would.
Definitely go for the springs. Pucks only lift it up, that's it.
Your ride will remain stock only if your vehicle is left that way.
I personally lifted my JK 4 inches when i got it and now Im finding myself looking at the performance leveling kit from TF.
I need to replace both drive shafts and put some stock springs back on to avoid any more issues for the time being.
OH9JK Jul 3, 2011 10:44 AM
Big lifts = big $$
There is more to consider than just the lift itself. Shocks, extended bump stops, extended brake lines, wheels or spacers, axles, gears, gussets, etc etc etc.
© 2026 MH Sub I, LLC dba Internet Brands
