just ordered new steering stabilizer
hey guys i just ordered a fox 2.0 steering stabilizer and the synergy relo bracket and tie rod clamp. is anyone running this setup? looking for some insight on the bracket and tie rod clamp install. cant find much on the forums. im mainly looking for info on correct placement of the synergy tie rod clamp. thanks again guys
Setting up the SS is the same with any bracket.
Bolt up to the axle. Turn wheel all the way to the right. Loosely bolt up clamp to tie rod and compress shock so there is about 1/4 shaft showing. Tighten clamp bolts, cycle steering to make sure nothing is binding .. Done.
