just placed an order. Did i forget anything?
how much farther do the brackets hang down?
If I were you I would run LCAs instead of the correction brackets. Mine got destroyed on the rocks over time.
I would also just get brake lines and not bother with drop brackets. I had drop brackets and had to bend the hard lines to get them to fit. When I finally went to new brake lines I had to bend the brackets back which was no easy task. The rears also didn't go back exactly to where they wre stock so right after I put the new lines on I caught the hard line on my rear sway link bolt and bent it pretty bad. Lucky for me I was able to bend it right back.
I bought the MOrE replacement hinges. the brace peace was out of stock. Ill get that later. Front bumper has the inexpensive shortening caps already. Rubicon rails are already trimmed and ready and theres no pinch seam (2015) Getting the spare mounted up right is something ill address when I see if it fits (stock willys rims with wheel spacers so stock offset)
