Leaking rear axle seals on 2012
So I've noticed my modded 2012 JKU is leaking gear fluid on both sides of the rear axle. My uncles and I are 100% sure it's failed seals. I have an appointment on Wed to confirm and get fixed, but I was wondering if anybody else has had this issue and if it was covered under warrenty with a modded Jeep? I have a 2.5in TF coil lift with 33' tires. I asked them when I made the appointment and their response was "depends if the pinion angle was changed". :doh:
The front inners leaked on my 12, not covered under warranty. But it was on 37", with beat in sleeves and ARB diff covers.
My 12 did the same thing bad seal on passenger side and the bearing was seized on the axle shaft. Dealer covered no problem I'm running a 3.5 AEV lift with 35's
Depends on the dealership... They get paid by Chrysler to do warranty work so if they think they can fix it fast they might do it... If they are busy with a bunch of easier jobs they might give you some bs reason.
If they say no just leave and take it to another dealership... Getting mad at them and/or leaving a bad review on them might get your jeep blacklisted like eddies, so you are better off just leaving. |
Thanks for the feedback/advice so far guys! hypeiv - believe me it's going to be hard to bite my tongue if they give me hell, but I know it'll get me no where showing my frustration.
Originally Posted by Redleg81
(Post 3490926)
You are better off taking it to a dealership that is happy to help you. Read this thread before you think about giving a dealership hell: https://www.jk-forum.com/forums/modi...r-jeep-132752/ If you get a survey about the dealership do no fill it out or, if you do, give them a glowing review b/c if you write bad things it will get back to them and they do have the power to blanket void your warranty. |
leaky seals
(Post 3490363)
Thanks for the continued advice/information guys! Good news my dealer will cover the repairs under warrenty. They first questioned what type of lift I had on it (mopar or non-factory) and if it was all ready on when I bought it (I ordered from factory new). I was honest and after waiting an hour they came back saying it would be covered under the warrenty but have to order the parts. Once parts are in, they said it'll take about 4 hrs to repair both sides. Now let's hope they do a quality job!
My 2012 is completely stock it's in the shop today for the left rear leaking.
Yup I had a Customer with a 2012 JKU the other day with a leaking right rear axle seal with no modifications yet and only 3,000 miles.
