The least expensive way to get to 35s
Here is the question!
What would be the least expensive way to run 35s but adequately address on-road handling (keep axle centered, correct castor)? Now I am at least two months away from being JKed so this is just for the joy of the discussion.
Here’s my idea using only parts from sponsors of this site.
$226 - TeraFlex 2.5 budget with shock adapters
$210 - Daystar adjustable upper front control arms (correct caster)
$180 - Full Traction adjustable front track bar (correct centering of axle)
$616 – Total
What’s your idea? What would be the disadvantages of such a “cheap” approach?
$616 – Total
JK-Forum Founder
$616 – Total
$616 – Total
I'm going to try and install a TeraFlex 2.5" BB with shock adapters and a M.O.R.E. 1" BL so that I can run a set of 35's. In my research, this is the cheapest way to get there and still have a decent kit. If more is needed, I will add it as needed. Depending on when I get my JK, I'll try to have a complete write-up on this setup done hopefully soon
I see that neither of us has addressed the issue of swaybar links.
I would think that at 2.5" you would be fine on stock control arms, and if it were me I would try it out on the stock track bar. No need to spend money if you don't need to. Especially if you want the cheapest method.
JK-Forum Founder
Thanks for the response, Wayoflife. My question to you is what about centering the axle and fixing the caster? Are you thinking that these matters are minor enough at 2.5 inches that perhaps they can be ignored? There have been enough reports on this site of issues with steering and tracking that it seemed better to include the cost of those fixes in the minimum needed.
If there are no problems, I will be sure to say as much. Likewise, if there are, I will try to explain them the best I can in hopes of informing people of what to expect or how to deal with it.
A premium lift with shocks will end up costing over twice as much... $1300-$1400 with shocks.
I would probably do this instead:
$430 - Skyjacker 2.5" lift kit w/shocks
$30 - 3/4" front coil spacers
$640 - Total
Then I would just live with the caster problem till you can afford the control arms later. It really isn't a problem that I've noticed on my 3" lift. You can't take naps on the highway anymore, but it's not a problem.
As for the anti-sway bar links, you could easily modify the stock ones to work with some steel tube and pins. This would even let you get your anti-sway bar arms parallel to the ground for the best on-road handling.
-E
$640 - Total
-E
