Leveling Kit or Wheel Spacers 1st
I only have 15,000 miles on the original tires so going to be running them until they wear out or I win the lotto. Once they do wear out, I'll put on 33's and more then likely buy them off of this site.
Want a better looking Sahara on the cheap which is why I am torn between the wheel spacers and the leveling kit.
Just need some help making that decision from all of you.
Thanks again.
Thanks again.
you're going to to be in between two issues.
first, if you offroad, you will notice rubbing on your fenders. if you don't offroad then you will not experience this.
second, is you will might rub your sway bar links. but, i think this is hit and miss, depending on the tire mfg you go with.
SO, what are you planning on doing with the jeep????????? Any offroading? or just Daily Driving?
