Out of level Jeep after RK lift
So after installing a Rock Krawler 2.5 Flex, My Jeep is out of level and I hate it! All measurements are from the ground to the pinch seem. LR 23" LF 22.25" RR 22.25" FR 22.25". Measurements are with a half tank of gas and about 1000 miles after installation. All springs appear to be seated in proper position. I've been racking my brain and need some ideas please. I may take both rear springs out and measure to see if they are the same length.
Called Rock Krawler and they suggested swapping the LR and RR with one another. Swapped them out. Same result. LR is still about 5/8- 3/4 higher 🤔 Completely baffled
What are the measurements with a driver in the seat? I always thought vehicles should be level they way they are driven.
It's not a lean. The rear drivers side is 3/4 higher than the front drivers side. It basically has the factory take on the drivers side.
