Lift and cruise control
Just installed an AEV spacer lift and now my cruise does not work. Is it a coincidence or could I have damaged something in the process? Suggestions.....2012 rubicon unlimited
Are you sure it was working prior? the 2" lift is very basic and hard to imagine that it would cause the cruise not to work. I have installed 4 of the 2" lifts in the past year and never an issue and never had to recenter the steering wheel on any of them. I am thinking in the absence of abs or other warning lights it is coincidence. Check the fuse and check to see if the brake pedal is not hanging low for some reason which will kick the cruise off.
All is working I must have a short in the switches on the wheel. It seems that when I use the " cancel button the city cruise doesn't work till I bang the wheel till the cruise starts working again. I must need a new switch.
