Lift Help!!!
I'M currently putting my lift on (2.5" RC spacer lift). I got the right rear all done, left rear is almost done but I can't get the link off. The inside nut closest to the link is pretty much stripped and the outside nut appears to be "stuck".
I've used about 1/2 can of WD40 o free it up, but im stuck. I don't know what to do. Please help
Thanks for the help! A small pipe wrench did the trick. I have everything done but front sway bar links. They just won't tighten on the drivers side. I was thinkng of ordering some front dicos to take care of this issue. But i need to drive this, this week to work, is it okay to drive without them installed?
I was thinkng of ordering some front dicos to take care of this issue. But i need to drive this, this week to work, is it okay to drive without them installed for a few days?
10 characters
If you don't drive like an idiot you'll be ok for a week. I've driven after forgetting to reconnect my discos. You def can notice the difference but if you remember you're not in a Porsche all should be ok. But do get it taken care of ASAP.
