JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Lift kit-abs problem (https://www.jk-forum.com/forums/modified-jk-tech-2/lift-kit-abs-problem-228785/)
Erock1974 Apr 22, 2012 01:12 PM
Ok I got a fabtech 3" lift I had a alignment done steering centered and all seemed good. Now the problem is when we go around certain corners the front locks up and the breaks and stearing shake. I was told we need to reset the ecu or would we be able to use a programmer to fix this issue. I also took it to a shop and had it hooked up to a diagnostic computer as we drove it and it should nothing even though the sensor went off but the dummy light didn't come on. Any suggestions would be appreciated..
Saharaunlmtd Apr 23, 2012 02:39 AM
AEV procal or just adjust your steering wheel off a few degrees down on the left side when tires are straight.
Erock1974 Apr 23, 2012 12:40 PM
Would the superchip be able to do the same things as procal plus more ?
monkers Apr 23, 2012 03:04 PM
it sounds like the steering wheel needs to be centered, Im not that knowledgable though, I dont think the Superchips will do that, the AEV Procal does it, but the Superchips can be used as a reader Im told. Im leaning toward the Superchips......
Erock1974 Apr 23, 2012 03:07 PM
I took it to the shop twice they said it was centered of course we are talking les schwab so maybe I need to go some other place. Damn wish I was smart enough to work on vehicles.
DanieltheManual Apr 23, 2012 03:20 PM
Why not read the how to project jk? Its simple to follow and you only need a 15mm wrench......you can learn, and soon you'll be teaching others too
OH9JK Apr 23, 2012 03:37 PM
Read this...
Project-JK.com - Jeep JK Wrangler Resource » Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Erock1974 Apr 23, 2012 04:04 PM
I will try that as dooms as the wife gets home I will let you know I come up with
Finisher Apr 23, 2012 04:24 PM
Just a heads up, I had a 3 in lift installed, tried to center the steering wheel according to the write up, messed up the ABS and the SRS. Wife had to take it back to the dealer and have it realigned. All I did was give it 1/4 turn and it set everything off. To many computer controlled features.
Erock1974 Apr 23, 2012 04:56 PM
That's not wanted I wanted to hear
© 2026 MH Sub I, LLC dba Internet Brands
