Lift Kit advice please!
Only 6 months? So that's why you jumped into a poor selection of RC lift on your 1st attempt. I'm on the over analyze and over research side of the spectrum. I spent 5 years in this forum doing what you described planning out my lift, deciding on the one I was going to purchase, and then installing it. Between, all the research, asking more specific question and getting great information and advise in this forum, and then actually installing the lift myself, I've come up to speed pretty well on understanding this suspension stuff that used to be such a foreign language to me. Still no expert.
I'll be honest though.....I also wanted to wait until I was out of warranty on my JK before doing any suspension mods since Chrysler hasn't been known for their "quality" in the past.
Being on these forums, I've come to the conclusion the majority fall into 2 types of learning classifications.
1. Jump in and learn from experience which comes at the expense of spending more money.
2. Hold off, research, ask questions, and learn more which comes at the expense of spending more time.
People always say Time=Money, so it all balances out. I fall into category #2, because I tend to have more time to spend than money.
R/
Will
Former Vendor
Any reputable shop will have a rig with their go to suspension kit installed for a customer to test drive. We lean heavily on JKS and EVO suspensions, so we have several different rigs for potential customers to check out at any time. Find a shop that you trust and go with their recommendation, they are responsible for whatever they recommend and for your satisfaction.
The worst thing for an inexperienced JK owner to do is to purchase a kit solely on the advice of the internet before you have gotten a chance to check it out for yourself. A $400 kit sounds good until you test drive it, trust me on that. The kits we recommend tend to be more complete and start around the $1200 range. I would plan on spending that at least. Buy something high quality from the start. A JK is a nice vehicle, it's very easy to make it not so nice to drive with cheap components.
Things often left out that you find out about afterwards are HD track bars, driveshaft, caster corection, brake line length correction, axle breathers. So plan on spending at least another $500-$1k on top of the listed lift price.
Some of the most "complete" lift kits out there are the Metalcloak game changer kits and even those could be better by adding a replacement drive shaft which is another $500.
Whatever, you decide to get post the contents of that kit here, and there are many here that can recommend additional components you will likely need to add or could benefit from replacing what was put in the kit with a better solution for solving the same problem.
Former Vendor
I would also emphasize the "complete" aspect here when shopping for lifts. Most of the kits available are not "complete" especially when you add larger tires, which should be the major reason you're even considering getting a lift. They all seem to leave something out or provide some kind of compromise solution. So expect to pay extra on top of the listed kit price if you want to get the best out of that kit.
