Lift kit opinions/ choices
#31
Most brackets do not correct for the binding as it is a result of the axle rotating and throwing all the brackets off. This is why so many people have their coil bowing. Just raising the bracket will help center the axle if you are not using an adjustable track bar but also helps the axle shift from side to side because it moves on a flatter arc. On a short arms suspension as you droop the pinion angle rotates up making the bind worse, so the more down travel you have the more bind you will get from the track bar joints. This is a good reason to make sure a long travel suspension has plenty of up travel and not all down.
#32
Makes sense. Thanks for the further details. Wouldn't the misalignment concern you mention be corrected by using a raised axle side track bar bracket or is my thinking incorrect? From my understanding you want to keep the TB parallel to the axle. With an adjustable TB you're able to get the length dialed in so the side to side alignment is centered but you increase the angle the more you lift as you outline, and this is where a raised TB bracket assists to correct that misalignment. At least that's how I currently understand it. I do personally prefer the maintenance free aspect of a factory style joint over that of an open joint and the additional flex it provides.
#33
Right at 2" of lift and 9"-10" of shocks travel it is not going to be a big deal but as you go taller with more shocks travel and uneven travel ratios it becomes an issue.
