Lift kit suggestios
Old May 13, 2013 | 09:38 AM
rpc2638's Avatar
Default Lift kit suggestios
Alright guys I currently have the rough country 4" short arm lift. And just like the name it's rough, but has done what I have wanted out of it. Gained ground clearance bigger tires and treads over sand decently. But now I'm looking to upgrade. And was told by a friend if I where to go with a long arm kit it would give me a smoother ride and a lot more flex.
Rough country has an upgrade long arm "Y" kit available. Has anyone used the "Y" style long arms? Will it actually smooth out the ride anymore or should I go with a different manufacturer?
I drive down a lot of washboard caliche roads and that's why I'm looking for a smoother ride. Don't wanna get rid of my Jk for another vehicle just yet.
Please inform me with y'all's expertise Jk knowledge!
Thanks!
Old May 13, 2013 | 12:48 PM
BigSteve's Avatar
Sounds like what you need is different springs and shocks. Upgrading the arms alone will not significantly change the stiffness of the ride.
Old May 13, 2013 | 12:54 PM
BeachJK's Avatar
I love the ride of my 3.5 RockKrawler springs matched up with Bilstien 5100's. I heard alot about the RC stiff ride. I'm really happy I went RK
Old May 13, 2013 | 02:45 PM
BigSteve's Avatar
I can second that. I have the Rock Krawler 3.5 inch Max Travel kit with Fox IFP shocks and it rides just as good if not better than stock.
Old May 13, 2013 | 02:59 PM
Smashboogie 4x4's Avatar
Former Vendor
Shocks and springs will make a huge difference. Most of our customers love the ride of the 5100's. They are an excellent shock and relatively inexpensive. If you spend more time off road then Fox is another great option but lets not forget about the RRD's that Rock Krawler makes. PM us if you would like a quote.
Old May 14, 2013 | 02:19 PM
rpc2638's Avatar
Your referring to "5100's" as in the spring rate? Or model number? And I will look up the RK kits. Thanks guys!
Old May 14, 2013 | 02:25 PM
SBEII's Avatar
5100 is the model number of Bilstien shocks.
rpc2638's Avatar
And will the 3.5" springs work with the 4" lift components I already have on the jeep?
Old May 14, 2013 | 02:26 PM
rpc2638's Avatar
O ok. Thanks!!
Old May 14, 2013 | 02:47 PM
Former Vendor
They should keep you very close. Are the arms adjustable? What about the track bars?
As stated above the 5100's are the Bilstien shocks.
