limiting straps?
Old Jul 13, 2011 | 05:52 PM
burr.1983's Avatar
Default limiting straps?
Rock Krawler suggests using limiting straps with this 3.5 mid arm kit I just received... what are these and should i get them? Thanks for any advice.
Old Jul 13, 2011 | 06:11 PM
D_engel's Avatar
Limiting straps run between your frame and axles and prevent the axles from over-drooping which could cause your coils to pop out. Im not 100 percent on this but i think teraflex makes some limiting straps
Old Jul 13, 2011 | 08:46 PM
burr.1983's Avatar
yeah i found a bunch of them on 4wd product web sites. Are they a good investment do i need them? Do most people put them on after lifting their jk?
Old Jul 13, 2011 | 08:51 PM
dinojeep's Avatar
I think RK make retaining clips for their springs too.
Old Jul 14, 2011 | 07:10 AM
D_engel's Avatar
I personally would just get coil retaining clips, as opposed to the straps, so i can maximize droop without losing a coil. Just like the name implies, the straps limit articulation. You usually dont need them if you have the right shocks to go along with your lift.
Old Jul 14, 2011 | 07:13 AM
Biggy's Avatar
I have the rk 3.5 kit and I havn't had any problems running without straps or clips.
Old Jul 14, 2011 | 08:25 AM
Biginboca's Avatar
That won't necessarily apply to everyone though. It depends on what shocks you are running and what their extended length is since shocks are what limit your droop.
Out of curiosity, what shocks are you running?
Old Jul 15, 2011 | 03:45 PM
burr.1983's Avatar
I got bilstein shocks... northridge 4x4 hooked me up with them... i also have shock relocation brackets... what do you think I should do?
Old Jul 15, 2011 | 04:36 PM
aermotor's Avatar
I think the percentage of JKs that run limiting straps with 3"+ lifts is less than 1/2 a percent...
Old Jul 15, 2011 | 05:22 PM
DEADGUY11's Avatar
You absolutley do not want your shocks to be the limiting factor. You are supposed size your shock so that when the suspension is fully compressed (on the bumpstops)the shock itself still has room to compress and in full flex the shock is not fully extended taking the stress and weight of the suspension. thats where limiting straps do help as well.
