limiting straps?
Limiting straps run between your frame and axles and prevent the axles from over-drooping which could cause your coils to pop out. Im not 100 percent on this but i think teraflex makes some limiting straps
yeah i found a bunch of them on 4wd product web sites. Are they a good investment do i need them? Do most people put them on after lifting their jk?
I personally would just get coil retaining clips, as opposed to the straps, so i can maximize droop without losing a coil. Just like the name implies, the straps limit articulation. You usually dont need them if you have the right shocks to go along with your lift.
Out of curiosity, what shocks are you running?
I got bilstein shocks... northridge 4x4 hooked me up with them... i also have shock relocation brackets... what do you think I should do?
You absolutley do not want your shocks to be the limiting factor. You are supposed size your shock so that when the suspension is fully compressed (on the bumpstops)the shock itself still has room to compress and in full flex the shock is not fully extended taking the stress and weight of the suspension. thats where limiting straps do help as well.
