Limp Mode Help!
Limp Mode Help!
Hi everyone. I have an 08 JKU with a 42rle transmission. Last week I got a Shift Solenoid A fail (P0750). I replaced the solenoid pack and everything worked fine. This morning I get the same code and I'm in Limp Mode again. The only common factor I have right now is the first time it snowed outside and this morning it was 31 degrees. Otherwise it been warm. Is there possibly something with the oil viscosity making something fail when it gets cold outside? I drove it around a bit to warm everything up but it never comes out of Limp Mode. Any advice?
What did you do to diagnose the problem? Why did you replace the solenoid when there are multiple possible causes to the problem? You need to go through the entire list to rule things out. Or can replace parts, if time and money is not an issue, then come on a forum and ask why after replacing a part you still have the same problem.
Not very helpful but how many miles on the transmission?
