locked front options
........Just so I got this right. I can buy an Aussie for around $300 and have a kinda locked front end. (It "basically" works off of tire spin and resistance, correct?) Will work good for hill climbs and mud, but not so good when only two wheels are touching the ground. How does it perform against a log in the road? Do you still have to push / bounce the tire up and over?
No new gears needed works with the 3.21s?
I might go this route...
..............Thanks all
..............Thanks allYou only have to replace the spider gears inside of the carrier so your existing R&P will work. It is the cheapest way to get both front tires to pull when you need it.
Everybody agrees the PR44 is best, hands down, no shit category. But, then so are 60s and coilovers that cost $20K. I am extremely glad that companies like dynatrac are out there to provide us with excellant equipment when we need it.
I had an aussie locker in the D30 front of my old YJ with an 8.8 rear Full Detroit locker as well. I was totally surprised when I put the aussie up front expecting driveability problems similar to what my Detroit could give me when I wasn't paying attention.. lol
It never really happened with the aussie, so im sure in a JK it reacts the same way.
Now I had those lockers in that YJ for a reson, taking it to next level and knowing that as lockers go, automatics in general are the most reliable units you can buy for the trails. Before you decide to go this route ask the JK aussie guys how there's is working they will have better insight on a Jk dd aussie set up.. good luck either way.
This is what I have in my factory rear end, correct?
I don't like how it preforms back there. It never seems to lock when I want it to. Sure, if I'm at a stop on a gravel road, rev the engine and drop the clutch I can spin both tires (sometimes); but when I'm in a "off road" situation" I can never get it to lock. Example: I pulled off the snow cover road and the ditch had a large drop-off causing my front right tire (/suspension) to flex out and loose all downward pressure. Basically I should of had three tires with moderate traction. Granted the ground was snow covered so any traction was moderate at best. Anyway, the only tires that would turn /spin was the right front and the rear left. I was stuck.
Luckily, two big guys came along, bounce on the rear bumper, and I backed right out.
I'm guessing I didn't have much downward pressure on my rear left tire. I don't think it ever "locked" in the rear, just change from spinning the left to the right.
Maybe it's user error on my part (not knowing how to 'drive' correctly), but in my experience, a auto-locker (non controllable, non selectable) never locks when you need it to...
Thanks
I'm guessing I didn't have much downward pressure on my rear left tire. I don't think it ever "locked" in the rear, just change from spinning the left to the right.Maybe it's user error on my part (not knowing how to 'drive' correctly), but in my experience, a auto-locker (non controllable, non selectable) never locks when you need it to...
Thanks
The aussie, and similar, are lockers. Just you have to have some wheel spin for it to engage. This means both axles are locked together mechanically so they both are at the same speed and have equal torque. The aussie works off of inertia. If the wheels turn at different speeds it engages and stays engaged till the pressure or torque is released. As in if you drive in a straight line with light gas pedal pressure. As long as you keep the unit under pressure the axles are locked.
An example is when you enter a mud hole and loose traction one wheel will spin then the aussie will lock up; it stays locked till you are off the gas. As soon as both wheels turn the same speed and driveline pressure/torque is relieved it will unlock and act as an open diff.
An auto locker like Detroit Locker, Aussie, Lock-Right. E-Z Locker or Spartan is always locked unless it needs to unlock to navigate a corner. During a corner, the locker allows the outside tire (axle shaft) to over speed the driving inside tire (axle). As the corner is completed and equal tire speed (axle) has occured, the unit will again lock up.
A Detroit Sof-Locker is smoother than any lunch box locker. An Aussie is a good cheap option for a D30 axle if you have a driving style that won't cause you to break other axle parts.
A factory rear LSD is marginal at best. Truetracs are widely considered to be the best LSD available for off road use but they still don't perform as well as a true locker. Not everyone needs a locker. For many moderate off road users a Truetrac is a great option. For a moderate user that lives in an environment that gets a lot of compact snow and ice, Truetracs are the very best option. If off-road use wasn't considered, Truetracs are a much better option than a selectable.
Incorrect. As I mentioned in an earlier post, your stock Limited Slip Differential (LSD) rear axle came with a Trac Loc, not a Truetrac. No LSD locks. If a tire comes off of the ground or has significantly less traction than the other side, the diff will act like an open differential and allow the tire with little traction to free spin. This frequently can be helped by adding brake pressure to help equal out the friction at each tire and allow the differential push power to the tire with more ground traction.
I'm a little slow, so let's make sure I get this correct.
I have a Trac Loc, and a Trac Loc is a Limited Slip (LSD)
A Truetrac is a "Detroit Truetrac Differentials"?
Quote from Eaton website, "The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry."
I'm guessing the Helical Gear Type limited slip is better than (what ever type) limited slip the factory Trac Loc is... But they are both limited slip?
Apologizes if I'm beating a dead horse... just looking for that free education...
Thanks
Thank you for the clarification. I keep mixing the two as the same. Must be their names sounding so similar.
I have a Trac Loc, and a Trac Loc is a Limited Slip (LSD) Yes, but not a good LSD
A Truetrac is a "Detroit Truetrac Differentials"? YesQuote from Eaton website, "The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry."
I'm guessing the Helical Gear Type limited slip is better than (what ever type) limited slip the factory Trac Loc is... But they are both limited slip? Yes, Helical gear is better
Is this statement true for both the Trac Loc & the Truetrac? Yes, both are considered LSDsApologizes if I'm beating a dead horse... just looking for that free education...
Thanks
Thanks
