Is a long arm suspension more likely to get damaged playing in rock gardens?
Right now I have factory upper and lower control arms and I usually manage to bend one or two lower ones each year, so would a quality aftermarket lower control arm like an EVO be more likely to get damaged on rocky obstacles & hill climbs?
matthew
matthew
IF you are bending short arms you are likely going to bend a long arm since they will still use the factory axle brackets. Maybe you should pick better lines.
But in general there are obstacles where you have to get your front wheel over a large rock and where now the rock comes up and catches on the rock rail...but would it then come down on the long lower control arm instead?
How strong are the EVO control arms vs stock?
Matthew
matthew
The lower control arms mount to the factory brackets on the axle. The upper mounts on their long arm has a high mount that give better clearance on the top end vs kits that hang the frame side down. I am working on a double throw down with lever rear right now on a 2016 4 door. Its a quality kit but far from simple as far as the install goes. Lots of cutting and grinding, even the new brackets require quite a bit of grinding to get good fitment, mainly the front towers. The only axle side brackets are replaced are track bar and lower shock mounts. Lower control arms still hang down like an anchor.
You will drag long arms over obstacles more than is the case with standard length. Depending upon the bracket design you'll smack them from time to time. Most of the ones I have experience with take it all in stride.
