(Post 2457125)
yes, a short arm kit (what you have on your jeep now) would be more than adequate for your needs. if you're only planning to run 35's, i would recommend that you go with a 3"-3.5" lift as that will be all that you need and it will help to keep your center of gravity lower. also keep in mind that most lift kits yield more lift than what is advertised.
Long arm! That way you never look back and regret!
Originally Posted by EpicCosmo
(Post 2457129)
What is recommended in terms of arms? I know most kits have the ability for you to use the stock arms or to get adjustable arms. Are the adjustables really needed or do they give you better ability to adjust geometry and other things necessary for longevity of components?
sorry to hijack the thread but im on same boat.
im running 2.5 TF coil lift with 35' and i want to add 2' spacers should i get the short or long arms? |
