Need to level Jeep. Heavy Load in back end
I am planning a trip through the Rockies (Northern B.C.) and into Cali and Texas. I will be loading my Jeep up with a lot of gear and would like to know the best way to level the jeep back out because I know the ass end will be lower than the front.
Any ideas?
Any ideas?
JK-Forum Founder
if you're looking for a permanent solution, adding a 1" coil spacer in the rear will do the trick. if you want something more adjustable, you might want to consider an air lift:
http://project-jk.com/jeep-jk-write-...ation-write-up
