LS swap questions
First of all let me say this.. I am an LS guy. I've been running LS engines for over 10 years in my drag cars, but this will be my first swap in a JK.
I see most guys running the motec and rpm extreme setups when they do the swap, but Im not too fond pf spending 5k on the harness, mounts, etc. My question is...has anyone done the swap without using the custom harness, but still made their factory gauges, ac, heat, stereo work? My jk is a trail rig that I drive on the street as well, but it is more of a trail rig than anything so I'm not too concerned with the factory gauges working. I do want to use the heat and stereo though. If there is no way to keep those things operational I will just wire up the heat so it works and I will swap out the factory head unit for an aftermarket head unit. For gauges I will use a tablet or edge CTS2 monitor like I have in my dodge. I'm also trying to decide on the best headers to use. https://cimg8.ibsrv.net/gimg/www.jk-...929bf680b7.jpg Thanks in advance for your input. |
I can't answer your questions as I used an RPMextreme kit. You need to call and talk to Jon at RPM and talk about what you are wanting as he may be able to meet your needs with what you are after.
Ametzker has a current work in progress thread (link below) going on, where I believe that he has the same plan but I'm not sure if he's far enough along.
https://www.jk-forum.com/forums/modi...8/#post4304283 I'm just waiting for someone with much more experience to come along and let us know what can and can't be done without one of the conversion kits. :D I like knowing what $5K gives me in return when I eventually do my LS swap. |
DaMangler - Are you the same fellow from FB who asked this? If I remember correctly, you basically want a trail rig, not a street legal rig? If trail, loose the Jeep CANBUS system and just run aftermarket gauges.
If you want street legal, I'm seeing two methods. 1. You have to figure out how to tie into the CANBUS system of the jeep. This allows access to the ECM and to the TIPM so your gauges and turn signals and all that stuff works. 2. Loose the Jeep CANBUS entirely and re-wire your jeep to run on the GM ECM. That means new gauges and wiring your own amenities (turn signals, brake lights, heating controls, etc). I'm running a 2011 L96 w/6L80E that MoTech installed for me, so I've got their box that allows the GM and Jeep ECMs to work with each other. If I had it to do over. I would have found a salvage title JKU and gutted it. Then installed an LS and wired the rig myself. (Did this with a 72 Cuda that now runs a 6.1L Hemi with a 4L60E trans) That's not a knock against MoTech. The work they did on my rig is better than factory looking and works without flaw. I've just reach a point on my rig that hardly any of the original jeep is left other than the tub. Regardless, create a build thread and post up because I'm very interested to see what direction you go. I like to see folks do something different (like my Cuda with a GM transmission). |
Originally Posted by jedg
(Post 4314112)
Originally Posted by DaMangler
(Post 4314148)
I already have an aluminum 5.3 but I need to decide on a trans and case.
I'd talk to Motech...IMO best option if your wanting JK elect integration done right.
Originally Posted by jordy
(Post 4314158)
You've got the 4:1 Rubicon case, so you're good there, unless you want to step up to a twin stick Atlas or the like. I'm planning on keeping the Rubicon case, but I've also got hubs on the front Dynatrac, so there isn't that big of a benefit in a twin stick for me. To me, the biggest appeal, aside from an extra couple hundred ponies, is a 6 speed transmission behind it. Going with a GM transmission as well when I pull the trigger.
Originally Posted by caryt
(Post 4314260)
(Post 4314356)
The whole point of this thread is because I don't want to spend that kind of money because I don't really need all of the jeep stuff to function. I'm just going to do the swap the old fashioned way. All I need is lights, radio and heat to work. No need to spend 5k on a swap kit just for that.
Edit - here's the article http://www.fourwheeler.com/features/...ed-earthquake/ Edit - Edit - hands down one of my top 3 JKU rigs ever. Like I said before... if I knew then what I do now, I would have found a salvage title JKU. Gutted it and built from scratch. |
