Lug wrench / lug nut question with new wheels
I replaced my stock wheels with Pro Comp 8107's. The area around the lug nut is smaller than stock and the large OD of the factory wrench restricts it from being able to grab the lug nut. I can use a deep thin wall socket or thin walled 4-way to get around this problem, but was wondering if there are any adapters that I could use with the OEM lug wrench to keep it simple?
Keeping a 4-way in the jeep is handier than an adapter that may become lost or left behind at home so when you need to use it, it's not there!!!!!!
Try the Gorilla Wrench. It comes with 2 deep sockets (4 sizes-so choose the right one, connect, leave it), provides better leverage and is Compact/extends. What I also like is that the angle allows you to access the lugs that are deep inside from the wheel edge. Approx $15 at walmart
I replaced all mine with wheel spline lug nuts.
"Adapters are made for small diameter lug holes. They feature a closed end design, more gripping power, a larger seating surface, and extended stud engagement."
They also act as wheel locks cause you get your own spline tool that only fits your splines.
hxxp://www.customwheelaccessories.com/SplineLugNuts.html
