Metalcloak Thread
Old Jun 4, 2014 | 07:46 AM
  #1361
snags922's Avatar
Never mind my last post. I see you already answered it. Thanks. I think this is the fix that I will be using.
Old Jun 4, 2014 | 07:59 AM
  #1362
olram30's Avatar
Pretty interesting to watch people argue over limit straps. So far I've heard they are dangerous, limit articulation and to expensive. They are perfectly safe and protect your shocks, and keep your coils seated. Some of you act like your running 14" coil over shocks. Just buy a after market drive shaft and call it a day. Try using the factory one and the boot by the tf case will still blow out with all these spacers and y pipes.
Old Jun 4, 2014 | 08:03 AM
  #1363
14Sport's Avatar
Originally Posted by Invest2m4
Back AND down. Lose ground clearance and put the crossover below the crossmember. Great idea if you have a shop (or yourself) cut and weld a couple pieces in and push it back and not down. If you are going to be flexing enough to need the fix, then you don't want to push the exhaust down.
I was just referencing that video for the measurements. I was thinking of going with aFe y pipe. Is that a good solution? Do you know if the loop delete pipe affects performance? Not sure if it is a different length than the loop but can't imagine that it isn't shorter. Qtec has the combo for 350 but if it affects performance I will just go with the y. Thanks.
aFe Power 49-46217 - aFe Power Mach Force XP Loop Delete Pipe & Y-Pipe Combo for 12-14 Jeep® Wrangler Unlimited JK 4 Door with 3.6L - Quadratec
Or would it just be better to go to a muffler shop and have them push the crossover back? Sounds like that may be cheaper.
Old Jun 4, 2014 | 08:27 AM
  #1364
Invest2m4's Avatar
Originally Posted by 14Sport
I was just referencing that video for the measurements. I was thinking of going with aFe y pipe. Is that a good solution? Do you know if the loop delete pipe affects performance? Not sure if it is a different length than the loop but can't imagine that it isn't shorter. Qtec has the combo for 350 but if it affects performance I will just go with the y. Thanks. aFe Power 49-46217 - aFe Power Mach Force XP Loop Delete Pipe & Y-Pipe Combo for 12-14 Jeep® Wrangler Unlimited JK 4 Door with 3.6L - Quadratec Or would it just be better to go to a muffler shop and have them push the crossover back? Sounds like that may be cheaper.
Muffler shop. Probably talking $50 and it's the best solution.
Old Jun 4, 2014 | 08:35 AM
  #1365
14Sport's Avatar
Thanks, Invest2m4, appreciate the help. That is the route I will go.
Old Jun 4, 2014 | 04:32 PM
  #1366
kjeeper10's Avatar
Vet Army
Great idea moving the exhaust back. Doesn't Rancho also offer a relo pipe.
Old Jun 4, 2014 | 04:42 PM
  #1367
Invest2m4's Avatar
[QUOTE="kjeeper10;3925146"]Great idea moving the exhaust back. Doesn't Rancho also offer a relo pipe.[/QUOTE
Same deal, but worse. It essentially curves the pipe down to clear the driveshaft. Although, if used while off roading, it's a very effective way to remove your exhaust system.
Old Jun 4, 2014 | 05:56 PM
  #1368
rsbmg's Avatar
They need an emoticon of a train coming off the tracks
Old Jun 4, 2014 | 06:10 PM
  #1369
Bypass's Avatar
The AFE pipe works fantastic and takes about 15 min to install with power tools. 30 min without maybe.
Old Jun 4, 2014 | 06:39 PM
  #1370
TheDirtman's Avatar
Originally Posted by olram30
Pretty interesting to watch people argue over limit straps. So far I've heard they are dangerous, limit articulation and to expensive. They are perfectly safe and protect your shocks, and keep your coils seated. Some of you act like your running 14" coil over shocks. Just buy a after market drive shaft and call it a day. Try using the factory one and the boot by the diff will still blow out with all these spacers and y pipes.
I am running 14" coil overs, well... on the front. 16" rear coil overs. I just have not messed with the newer jeeps.
