Minimum needed for lift
#21
Originally Posted by gint2
can they be adjusted while mounted or do you need to remove to adjust? Also, do you know if the Currie CA's are the same? I thought the Currie uses a rubber bushing on 1 end to reduce road vibs.
#22
#23
I had these questions, and many more... Please check out this thred... Especially the last 3 pages or so.
https://www.jk-forum.com/forums/show...+lift+concerns
I did install an OME HD kit and am VERY happy with it..
My backup plan would be to do the tereflex leveling kit with OME shocks, and Airlift airbags in the back... If I needed more clearance for tires... fender trim. Low center of gravity is better anyhow!
