mopar 4'' lift info
mopar 4'' lift info
swapping out an RE 2.5'' for the mopar 4''...the RE didn't come with any leveling spacers and the rear sagged a bit...im looking at the pics online for the mopar 4'' and notice the same sag...anyone on here running a mopar 4'' can confirm and if so what size leveling puck should i run? plan on installing this thing on saturday.
Hopefully you're planning on a different form of caster correction than using the cam bolts in that kit.
I recently put the MOPAR 4" on my 2009 JKU-R, and the rear actually sat noticeably higher than the front. So much so that I removed the MOPAR rear coils and reinstalled the factory coils and some 2" budget boost pucks I had on the shelf. Now it sits perfectly level with a lightweight front bumper, Warn Powerplant winch, and modified stock rear bumper with no spare tire.
My rig has a factory installed 4" Mopar lift. Never noticed any sag, haven't examined the lift to see if they did anything unusual either (2011 purchased used in 2012).
Attachment 675722
Attachment 675722
Yes, dealer installed, my error. Actually the measured lift is closer to 3.5". I have no added weight to the rig (i.e. no aftermarket bumpers). The lift was installed in 2011. HTH.
