Mopar Combustion Chamber Cleaner
Anyone used MCCC in their 3.6? I’ve used it on tons of vehicles with no issue and great results, but I used it on my 3.6 JK for the first time the other day and I swear half the can just poured back out of the throttle body once I shut the engine off. I can tell the TB is angled downwards, I assume that’s to help keep liquids from making it to the engine. But because of that I had to turn the engine back on several times to get all of it sucked into the manifold. I never got the smoke I normally get either. Makes me wonder if any of it actually reached the CC or if it’s just sitting in a pool somewhere. Is there a better way that someone knows of?
yep you spray it in while it’s running, when the can is empty you’re supposed to turn the engine back off. But when I turned it off the stuff just came pouring out. Turned it back on again and let it run for a minute or so to try and get it all in, turned it off and it started pouring again. Took about 5 tries and 5 minutes of running to get it to where it wasn’t coming back out anymore. Never had that happen on any vehicle ever. I feel like it didn’t even do anything because most of it poured out and I never got that huge smoke cloud. I’ve had people call the fire department before while using this stuff on other vehicles but this time I didn’t have so much as a puff of smoke
I've used it a couple times in my 3.8, as recently as last month actually. The first time I used it, there was smoke. The next time, not so much- I assume because there wasn't much carbon build up? The most recent time here, no smoke either, but it does seem to run a little better. I try to run most of the can through it then kill it while spraying the last little bit in there. Let it sit for 20-30 mins to "heat soak" and then start it up and go drive it. That's the procedure I found and used years ago, seemed to work out alright. I don't see why it would be any different on the 3.6 but now you've got me wanting to try it.
What kind of mileage were you at? I think I was at 75-100k, then 125k, and then at 220k. After 150k, I also started using a little seafoam here and there as well as 87 non ethanol and driving it HARD up mountains off-road. Maybe the additional stress burns the carbon naturally without additional cleaners?? Dunno, but it still runs so I'll keep doing what I'm doing.
Did you have the engine running about 1500-2000rpm while doing it? Also water/meth injection kits keep the engine clean forever. They are available for NA engines and one can run just water in them but the meth has performance value but not more than 50/50 mix ratio.
Correct me if I'm wrong, but the smoke has absolutely nothing to do with carbon build up. If you put this stuff in a brand new engine rolling out of the factory the same smoke will happen. Not too unlike what happens in an air show when the pilot creates the smoke by injecting some kind of lightweight oil onto the exhaust system. It is a myth to think that the smoke coming out of your Jeep is because it was dirty inside the engine.
I’m with Rob on this. It seems like snake oil. I’ve ran sea foam and Marvel in an engine before as one of its quarts of oil. I saw no difference in the oil draining out or sediment inside the waste pan, but it made me feel good that I was taking care of my car. I’ve ran sea foam and Marvel in the gas tank too. Not sure that even helps. I do like to run a can of injector cleaner once a year in the tank. Only benefit I see is I have slightly improved mileage on that tank of fuel.
Point is if you think it’s worth the money and time have at it. Maybe it was Chris Fix on YouTube, guy ran sea foam, techron and some other cleaner in a lawn mower engine. Interesting results.
