Mount for 4lb or 5lb fire extinguisher
I know there have been quite a few threads about fire extinguishers and mounts. However, most of them discuss mounting the smaller 1 or 2.5 lbs units. My work is requiring that all project managers that use their vehicles to travel to job sites to carry 4 or 5 lb ABC fire extinguishers. So I am looking for a good mount and mounting location for a 4 or 5 lb fire extinguisher.
Any ideas or recommendations? Would something like the power tank bracket work? Other similar products? Thanks. |
Smittybilt or powertank air tank mounts should work for your needs. There's also a variety of rollbar mounting options out there. A search should find you a lot of choices. Check out fourtrek as well.
me too, 5lb, have not figured anything out yet.
please report back with what you find. |
1 Attachment(s)
I don't recall the size but I put this at the left rear of the cargo area. You could probably fit a larger model back there as well.
Originally Posted by RAMbone
(Post 4067277)
1 Attachment(s)
I just secured it with some sheet metal screws, its been there 3 yrs, no problems.
take a look at the Drake Off Road fire extinguisher mount.
This is the tread I started with this same question. https://www.jk-forum.com/forums/modi...lution-315067/
Check out quick fist mounts, I use them for my CO2 tank and have no complaints
