My JK wont stay in 2,4,6,R after 1in BL
I found a post earlier about this but I can't find it now. I just know after my 1in BL I preety much have to hold it back into these 4 gears. How can I fix this?
So just use 1,3,5 :) just jk....did you lift the tranny with the body, so its not all out of wack
Originally Posted by thumperk15
(Post 253285)
I just did mine. Here is what you need to do...
1. Pry up on the back of the trim ring inside the jeep (use a small screwdriver wrapped in a rag) around the shifter, there are two clips in the back and in the front are two tabs.. Lift the ring and boot up and you will see the inner boot. 2. Once you have the inner boot in sight, on the back (rearward part) of the boot (where it connects to the body), you will see a lip that sticks up about 3/8" on the outside edge. Cut about 4" of that lip off. (You will see where the shifter makes contact with it in those bottom gears, just cut that area off). 3. Reinstall the outer boot/trim ring. 4. No more popping out of gear.:yup: |
That sounds about right...the hole in the floor pan is typically too small after a BL for the shifter to have room to row, so clearancing the part of the hole its hitting on is std procedure.
:D |
Thanx for the help everyone
BONDSMAN I'll do that first thing in the morning. |
(Post 253639)
I will post pics of the whole process in the morning as soon as I can.
Please do. I'm considering doing the same thing.
you BETTER get this fixed by friday so u can still go wheelin (even though i can't)
