my mirror solution
Just finished these last night in anticipation of my Bestop soft doors arriving :rollingeyes::D .
I think they turned out pretty good. Opinions? http://my.project-jk.com/data/1181/DSCF0828.JPG http://my.project-jk.com/data/1181/DSCF0829.JPG http://my.project-jk.com/data/1181/DSCF0830.JPG http://my.project-jk.com/data/1181/DSCF0831.JPG http://my.project-jk.com/data/1181/DSCF0832.JPG http://my.project-jk.com/data/1181/DSCF0839.JPG http://my.project-jk.com/data/1181/DSCF0841.JPG http://my.project-jk.com/data/1181/DSCF0838.JPG http://my.project-jk.com/data/1181/DSCF0842.JPG http://my.project-jk.com/data/1181/DSCF0833.JPG No contact with doors open, so you don't have to remove them when you put the doors back on. http://my.project-jk.com/data/1181/DSCF0834.JPG |
You could probably run them upside down also. Those look pretty good.
Originally Posted by Blue
(Post 442577)
Yeah, I thought about doing that or using the 2 bolts below, right in front of the factory mirror. I think they'd hit the factory mirror and/or door when you open it though. I wanted to try them this way first. I wonder if the lower bolt holes happen to be the same distance apart as the upper ones? Maybe this bracket will fit in either location without drilling more holes. |
I like them. :yup: Did you buy or make that bracket?
(Post 442577)
Looks great, where did you get them from?
Originally Posted by 2K1TJ
(Post 442591)
I wonder if the lower bolt holes happen to be the same distance apart as the upper ones? Maybe this bracket will fit in either location without drilling more holes. Edit: the lower bolt holes are farther apart. The Outlaw Mirrors actually use the upper door hinge when the doors are off. I think I like your way better and the look of it as well. |
That is a lot of mirrors! :D
I like the look of it by itself, but would drive me nuts to check 3 mirrors on each side. |
I put on the an old YJ mirror I had left over from my YJ days.
http://my.project-jk.com/data/501/me...459_Large_.JPG http://my.project-jk.com/data/501/me...457_Large_.JPG http://my.project-jk.com/data/501/me...458_Large_.JPG |
Those YJ Mirrors... they still available to buy? Was it a perfect fit for throwing those on? or did you do a little fabrication of your own?
Also, where did the mirrors come from 2K1TJ? |
| All times are GMT -8. The time now is 02:44 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
