Sponsored by:
Sponsored by:
My thoughts on lifts
Old 10-15-2013, 07:44 PM
  #31
TheDirtman's Avatar
Originally Posted by Bushmaster
What about a body lift to raise the fender flares to fit the larger tyres and allow for stock flex?
That works too, to increase room for up travel but will also raise the center of gravity as the body on the JK is very heavy.
  #32
Forum Tech Advisor
planman's Avatar
Originally Posted by Offroad
Great info. I totally agree that a Jeep with 37s and a 2" lift would outperform off-road one with 33s and a 4" lift. But why would it have a lower center of gravity?
The answer to this has to do with how suspension geometry affects anti-squat and brake dive.
Steeper control arm angles and the geometry if the mounting points affect the center of gravity of the jeep on steep climbs and descents.
A JK with stock control arm mounting points with the 2" lift will keep better traction on the front tires and have less hop of the rear tires on a steep climb than it would with a 4" lift.
The issue isn't about having a jeep that corners well. It's about the tires keeping traction on steep or off camber climbs.
Old 10-15-2013, 07:46 PM
  #33
big dr's Avatar
Body lifts tend to raise your center of gravity,, where as cutting the fenders, or getting flattys wont.
Thanks for a great read dirtman
  #34
TheDirtman's Avatar
Well said planman.
Old 10-15-2013, 07:56 PM
  #35
Offroad's Avatar
Makes sense. Thanks dirt and plan men for such a good info.
Old 10-15-2013, 08:11 PM
  #36
Forum Tech Advisor
planman's Avatar
Dirtman has some really good info here.
I'd contribute an example:
With flat flares and minimal trimming of the rear fender well pinch seam, 35" tires can be run on 4.5" or less backspaced wheels with stock front bumpstops and about 2" rear extended bumpstops. So, you could run shocks that measure up to about 15" collapsed in the front and about 17.5" collapsed in the rear without bottoming them out. To gain more than stock articulation (flex), you'd run as long a shock as your springs would permit, as long as the collapsed length of the shock was at or less than the 15"/17.5".
With the same flat flares and rear pinch seam trimming, 37" tires can be run with 1.25" front and 2.5" rear extended bumpstops.
So, as an example for someone wanting more articulation (flex) with a mild lift of 2.5"-3":
You can run OME 11.5" travel shocks (16" collapsed and 27.5" extended) with 1.25" front extended bumpstops and longer front brakelines--and longer front swaybar links if you run them off road with a Rubi disconnect system.
You can run EVO RockStar (or similar) rear skids/shock relocation brackets that raise the rear lower shock and swaybar link mounting points about 1.5" with 11.5" travel OME shocks (16.5" collapsed and 28" extended), 2.5" rear extended bumpstops, longer brakelines, and longer swaybar links.
With this setup, you would need springs that can handle 11.5" travel without unseating. The rear coils would need lower coil retainers. OME HD springs can handle it. Metalcloak and Rock Krawler 2.5" springs should be able to handle it.
With 11.5" travel at the shock, you will want a flex joint (spherical joint) at atleast one end of at least the lower control arms. The front axle side upper control arm bushings in the axle will last longer if the front upper arms have a joint at the frame side instead of a bushing.
That setup, with appropriate adjustable trackbars, will RTI 1000 on a 2 dr JK with close to stock wheelbase.
The setup significantly increases articulation (flex) over stock because the combination of shock lengths and rear mounting points, extended bumpstops, longer brakelines, longer swaybar links, longer uncompressed spring lengths, etc. allows the full use of 11.5" travel shocks.
I haven't ever measured the actual usable shock travel with the stock setup, but I would be surprised if more than 7"-8" shock travel is useable.
Old 10-16-2013, 05:09 AM
  #37
TJJK's Avatar
Dirtman has some really good info here. I'd contribute an example: With flat flares and minimal trimming of the rear fender well pinch seam, 35" tires can be run on 4.5" or less backspaced wheels with stock front bumpstops and about 2" rear extended bumpstops. So, you could run shocks that measure up to about 15" collapsed in the front and about 17.5" collapsed in the rear without bottoming them out. To gain more than stock articulation (flex), you'd run as long a shock as your springs would permit, as long as the collapsed length of the shock was at or less than the 15"/17.5". With the same flat flares and rear pinch seam trimming, 37" tires can be run with 1.25" front and 2.5" rear extended bumpstops. So, as an example for someone wanting more articulation (flex) with a mild lift of 2.5"-3": You can run OME 11.5" travel shocks (16" collapsed and 27.5" extended) with 1.25" front extended bumpstops and longer front brakelines--and longer front swaybar links if you run them off road with a Rubi disconnect system. You can run EVO RockStar (or similar) rear skids/shock relocation brackets that raise the rear lower shock and swaybar link mounting points about 1.5" with 11.5" travel OME shocks (16.5" collapsed and 28" extended), 2.5" rear extended bumpstops, longer brakelines, and longer swaybar links. With this setup, you would need springs that can handle 11.5" travel without unseating. The rear coils would need lower coil retainers. OME HD springs can handle it. Metalcloak and Rock Krawler 2.5" springs should be able to handle it. With 11.5" travel at the shock, you will want a flex joint (spherical joint) at atleast one end of at least the lower control arms. The front axle side upper control arm bushings in the axle will last longer if the front upper arms have a joint at the frame side instead of a bushing. That setup, with appropriate adjustable trackbars, will RTI 1000 on a 2 dr JK with close to stock wheelbase. The setup significantly increases articulation (flex) over stock because the combination of shock lengths and rear mounting points, extended bumpstops, longer brakelines, longer swaybar links, longer uncompressed spring lengths, etc. allows the full use of 11.5" travel shocks. I haven't ever measured the actual usable shock travel with the stock setup, but I would be surprised if more than 7"-8" shock travel is useable.
I shouldn't have slept during high school geometry classes.
Old 10-16-2013, 05:13 AM
  #38
Maertz's Avatar
Well said by planman also. Imo on travel over 12" you should use coilovers and if for some reason you dont you will need a long coil to keep then seated wich will generally throw lcog out the window... This is of course assuming your not cutting and welding anything. As he said even on 11.5 you will need to retain the rear.
Old 10-16-2013, 06:02 AM
  #39
mudbug79's Avatar
This is one of the most informative threads i have read on this forum. It is great to get a break from the usual "what lift to get" threads.
Old 10-16-2013, 06:31 AM
  #40
Jersey_Devil's Avatar
It's know I've been paying this thread by but i decided to take a look today and WOW this has got to bio the MOST informative thread on here! Great job op
Sent from my obama listening device
Quick Reply: My thoughts on lifts
